BV avant 55 - upgrade from HDMI1.4 to HDMI2.0
This post has 15 Replies | 2 Followers
doun
Posts 25
doun Posted: Wed, Jan 7 2015 2:24 PM
Dear all,
As far as I know, the new BEOVISION Avant 55 supports, for the moment, only HDMI 1.4 ports. Is it possible to upgrade via a software update these ports to a HDMI2.0? Or will a hardware update be required?
Is a HEVC decoder (hardware or software) available inside the TV?
Thanks for your answers.
Kind regards,
Didier
Raeuber
Germany
Posts 2,542
Raeuber replied on Wed, Jan 7 2015 2:30 PM
Hello Didier,
a software update to support HDMI 2.0 is announced for this year.
HEVC will never be available for Avant because of the lack of required hardware components. That's why the Avant will soon be outdated.
Regards
Räuber
Radiomekaniker
Posts 49
Hi I was told that HDMI 2.0 (plug 1-5) and hdcp 2.2 (plug 1) will be a part og the next firmware update maybe in March
Yes - thumbs up
mawheele
Posts 258
mawheele replied on Wed, Jan 7 2015 10:03 PM
Raeuber:
Hhhhh???  HEVC inside the Avant is irrelevant. You'll get it from whatever you actually use to view streamed or broadcast TV - e.g. Sky box or AppleTV or any other.
doun
Posts 25
doun replied on Fri, Jan 9 2015 7:58 AM
Hello,
I am not sure it is so irrelevant than that. If the Webmedia application includes Netflix, it will be very interesting to have a HEVC decoder inside the TV.
Indeed, Apple TV is currently not supporting HEVC!!!
Kind regards.
JOCA
Posts 6
JOCA replied on Thu, Apr 9 2015 10:31 PM
Is something moving here? Were are already April.
when will the upgrade To hdmi 2.0 be available?
JOCA
Posts 6
JOCA
Posts 6
JOCA replied on Thu, Apr 9 2015 10:34 PM
is the update to hdmi 2.0 still expected? We are already April.
many thanks
joost
Millemissen
Flensborg, Denmark
Posts 14,680
doun:
Hello,
Kind regards.
There will never be a Netflix app on the current Avant SmartTV platform.
You will be able to connect any external box supporting 4K (HEVC encoded) material to the HDMI ports after the coming update.
These boxes will do the encoding - so no big deal.
The biggest problem is, that (apart from a few exotic boxes) there hardly is any external hardware with HEVC support yet.
This and the lack of (4K) content makes it easy to wait for the update....even if it should be delayed a couple of months - IMO!
JOCA
Posts 6
JOCA replied on Tue, May 5 2015 4:21 PM
The update to HDMI 2.0 came this night 04/05.
B&O delivers as promised. Their approach makes very much sense: they deliver the right "screen" and sound and stay away from very quickly charging image processing technology. They make sure the right "image connection" can be done.
I believe their technical product marketing could be better. It took me a while to be convinced And particularly when they introduced HDMI 1.4 without explaining the update work. Maybe I missed it.
JOCA
Posts 6
JOCA replied on Wed, May 6 2015 7:53 AM
And connecting a MacBook Pro supports very well 4k as well as far as I can see.and hear.
Must be a Mac after end 2013 + use thunderbolt + HDMI Cable.
is this also the experience of others?
JOCA
Posts 6
ari
Posts 144
ari replied on Wed, May 6 2015 10:26 AM
Indeed, my mid 2012 retina MacBook Pro outputs 4k on the HDMI port alone and it works great. I just needed to use SwitchResX app to get 30fps as I was getting frame drops in 30fps material when connected over 25Hz.
Interestingly, SwitchResX also says a 60fps/60 Hz option, but I really don't think the rMBP is capable of 60fps output from the port.
Michael
Sweden
Posts 2,578
Michael replied on Wed, May 6 2015 10:38 AM
You could connect a 4K capable Mac to the Avant even before the update. Doesn't make any difference at all since the Mac is not HDMI 2.0 compatible - meaning it can not provide 60 fps over 4K. I haven't got any HDMI 2/4K60FPS devices to try but I suppose they should work now too.
And don't forget that Youtube on the Avant is NOT 4K, even if some people think so :-)
Sweden, Skövde
Posts 59
Martin replied on Wed, May 6 2015 3:12 PM
You can drive 4k 60hz on a Mac but through Thunderbolt 2 port, not hdmi.
Michael
Sweden
Posts 2,578
Michael replied on Wed, May 6 2015 3:52 PM
Over display port - to a monitor that supports that, which Avant does not. Just to be clear.
Page 1 of 1 (16 items) | RSS
