Morning members
my querry is , i connected my bs9000 to avant vhs with masterlink.
wht button should i press on beo4 remote to work it?
n should i have to connect speaker to bs9000 ?
i want sound come frm inside avant.
plz guide me.
thanks in advance
rgds iiirshad khan
Hi Irshad,
TV should be in V.OPT 2 and 9000 in A.OPT 0 if in the same room and connected by ML.
Sound will then come through your Avant
i did do v opt 2 n a opt 0 in t v n bs9000 . but still no soiund.
plz tell me which botton press n beo4 to start t v after selecting the both option
thank in adance
AHa a little b it of experience for you :)
Check that you haven't got the speaker type set to fronts because by default the 9000 connected to an avant with a the wrong settings for speaker will try to play through the front speaker pair.
If you don't know how to do this just press CD (CD should light up in the tv display top rhs) and then press LIST repeatedly until you see SPEAKER.
Then press 1 (1 isolates all other settings and just plays through the tv speaker)
Any response ? Everything sorted? Thanks
