Beocom 2 charging pins polarity
GPM
Posts 4
GPM Posted: Mon, Jun 8 2015 7:31 PM
Hello!
I'm trying to get a temporary solution to a problem I've encountered and I need to know the polarity for the Beocom 2 desk dock charging pins.
If anyone here could measure theirs with a multimeter and help me by telling me which pin is the positive (+) with the phone facing you, the front one or the back one?
I don't have a working desk dock / charger or multimeter handy to do the measurement myself.
Thank you!
PathElectronics
Posts 8
Negative is facing you (keyboard side of the phone.)  As you probably know, it just uses the two end contacts, the middle contact on the phone is for S/W flashing.
GPM
Posts 4
GPM replied on Thu, Jun 11 2015 12:22 PM
Thank you! Yes, I know the middle pin is for flashing, just didn't know which one was the negative and which was the positive.
I have no way of getting a dock now so not wanting to leave the battery discharged for a long time I thought to use something similar with a 5.4 V supply to try to 'emulate' the charger until I get a replacement. Hope it doesn't have any kind of magnetic switches or anything like that that would make charging more difficult. That's why I asked, since I didn't want to just try blindly and then have blue smoke. :)
I'll try it out. Thanks again!
Page 1 of 1 (3 items) | RSS
