Play V1-32
This post has 3 Replies | 0 Followers
Seanie_230
UK
Posts 2,278
Seanie_230 Posted: Wed, Jun 10 2015 7:43 PM
Hello all
If I swap out my beovision3-32 for a V1-32 would I still be able to pull master link sound and accept standard definition TV from the modulator in the bv7 in the main room?
I assume the moment would be able to push : pull sound to the v1 once the it has the software update?
Cheers all
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Andrew
Frinton, UK
Posts 917
Andrew replied on Thu, Jun 11 2015 11:34 AM
I didnt think the v1 had masterlink or could act in the same way - if that's the case maybe an 8-32 with the system board included
Steven_London
Posts 51
The V1 has neither masterlink connection nor the ability to connect to link video. I think (but not tried) you can listen to audio sources on a V1 if a Masterlink to Network link convertor is added.
Steve
hfat
Vienna, Austria
Posts 663
hfat replied on Thu, Jun 11 2015 12:30 PM
You could do it, using a BeoLink Video and Lintronic Box Digout connected to the analogue AV connector of the V1.
I'm using it this way
hfat
Page 1 of 1 (4 items) | RSS
