mute speaker 1 or speaker 2 on BM 7000
This post has 5 Replies | 0 Followers
erandlux
Posts 116
erandlux Posted: Sun, Jun 17 2012 2:25 PM
Hello,
I have a BM7000 with 2 pairs of beovox, is there a way to mute speaker 1 or speaker 2 via the beo4 ?
I search around, but found nothing helpful.
thanks
lausvi
Helsinki - Finland
Posts 689
lausvi replied on Sun, Jun 17 2012 2:30 PM
Speakers connected to the Speaker 1 -output can be muted by pressing MUTE on remote (on Beo4: press the middle between vol up and down- buttons), or by pressing MUTE on the front panel of the BM.
erandlux
Posts 116
erandlux replied on Mon, Jun 18 2012 10:46 AM
Thanks, but Is there a possibility to mute either speaker 1 or speaker 2 ?
Depending ln the situation, I want music in the kitchen and not in children playroom, or the other way round, not in the kitchen but in the playroom ?
tournedos
Finland
Posts 7,357
tournedos replied on Mon, Jun 18 2012 1:47 PM
erandlux:
Using only what the Beomaster itself has, the answer is a definite no - speaker 2 will play always.
You need to set up an MCL link system in the other room if you want to control those speakers separately.
--mika
stefan
200 miles from Struer
Posts 2,920
stefan replied on Mon, Jun 18 2012 1:52 PM
Yes, just add an MCL2A (Extra Speaker Kit) to your BS7000, and you can mute both rooms separately. It is also possible to control the BS7000 from both rooms and set a Timerplay or a System Standby...
Stefan
erandlux
Posts 116
erandlux replied on Mon, Jun 18 2012 2:59 PM
Ok, thanks to all of you.
I just added a pair of beovox 3000 to my system last saturday, I will have to install the xtra speaker kit I have somewhere in the basement, the one I bought last year, and that I never succeeded to install.
Page 1 of 1 (6 items) | RSS
