Hi Everyone.
I've just stuck my toe into the B&O world after being a fan for many years(family in Denmark)
and thought I'd tell you what I've bought and then seek your advice. I'm from the UK but currently
living in Spain where the prices seem a lot higher but I've tracked down the B&O in Murcia which
seems to be the closest to me so I'm hoping they can supply spares.
I recently picked up a Beocenter 9500 with a pair of CX100's, all good and clean the seller
told me So I bought a re-foam kit for the CX's as they had perished which was the easy
fix. The other problems I have with the 9500 may be down to UPS bouncing the box around
but I'd rather have you opinions before I accuse them. Also I've managed to buy a Beolab 6000
cheap so if anyone's got a spare one let me know
1. The glass fell out making a mess but I've found the pre-cut tape online to sort that out but
I'll wait until other parts are fixed.
2. The tape player motors make a noise as they should but no movement forward or back, I'm
hoping this is just belts that need replacing.
3. The CD opens and closes correctly and I've even had it playing an old disc but the other 200 disks
refuse to play and the door re-opens for the disk to be removed. I've read up a bit on here and wonder
if it's the C2103 with a 47uF 25v Vishay blue capacitor problem. If it played nothing I'd understand but just a very old disk & no other confuses me.
Anyway enough of my problems, I look forward to hearing from you.
Cheers
Marsh
Hi Marsh,
I just sent you an email with the details of a gentleman based in North London who can both explain and fix your issues.
Dan
Cheers Dan
You are a gent and there's very few of us left
