Hi, Just wondering if it's at all possible to watch video on scart 1, whilst listening to sound on scart 2? I'd like to be able to listen to my ipod while I game.
If not, is there a box solution that can do this?
Thanks.
probably not the answer you were wanting to hear: If your Avant has a Master Link socket, one method would be to get an audio master that also has Master Link. Connect the audiomaster to your TV and connect your iPod to the aux-input on the audiomaster. Set the Avant to option-2 and the audiomaster to option-0.
Start up your video game. Then select A-Aux to stream audio from the Aux-input on the Audiomaster to your Avant. The TV screen will show the game and the speakers will play the audio from the audiomaster.
-Brian
