BeoSound 3000-3200? VOLTAGE???
This post has 6 Replies | 0 Followers
striker27
Posts 64
striker27 Posted: Thu, Dec 20 2012 8:52 AM
I am located in North America.   But would like to get a Beosound 3000 or 3200 from the UK they are much cheaper and just use a 220V to 120V converter.  Could I just plug the Powerlink cables into my existing Beolab 2500's I have set up with my Overture 4000 from North America using 120 volts? Or is that asking too much???
Just wanted to know..
THANKS
The Secret Alpaca
Somewhere in Europe.....
Posts 46
Hello,
That would work perfectly - the PowerLink doesn't alter from region to region, so there'll be no compatibility problems at all!
valve1
The south of France and occasionally Dublin Ireland
Posts 1,502
valve1 replied on Thu, Dec 20 2012 4:57 PM
striker27:
Would you save enough by the time you pay p&p then buy a transformer  ? I would check both first before buying from outside N America.
Søren Mexico
Mexico City
Posts 6,411
I was just surfing the US bay, Beosound 3000 USD 1000.00 to 1500.00 buy now prices.
Leslie
the Netherlands City
Posts 5,423
Silver Member
Leslie replied on Thu, Dec 20 2012 9:43 PM
I think you can modify the BS3000 by changing links on the transformer from 230 to 110VAC.
Got oneSmile
Brengen & Ophalen
striker27
Posts 64
striker27 replied on Fri, Dec 21 2012 3:41 PM
I already have a transformer.  Sadly the units seem to be quite a bit cheaper on Ebay UK last time I checked but it has been awhile.  I am going to have to look closer at the total price.   The BS3000 and 3200 are a bit nicer then my Overture and I am looking at upgrading in the future.  I might look at the BeoSound 4 if I can find one for a good price.  I just really need what ever system I buy to have masterlink.  I have a few rooms wired up to my system as it stands now.  I do wish I could find out what to change on the transfomer though..
THANKS
Søren Mexico
Mexico City
Posts 6,411
Leslie:
Got oneSmile
Changing the transformer to from 240V (GB), to 120 V. a 3M3 Ohm resistor has to be added, and the fuse(s) changed to 125V type.
Page 1 of 1 (7 items) | RSS
