A9 Keyring ; Lutron compatible ?
This post has 11 Replies | 1 Follower
Simonbeo
Posts 1,451
Simonbeo Posted: Thu, Apr 23 2015 7:10 PM
Quick question, as in the title . Does the A9 Keyring switch the lights off if they're Lutron as operated by the Beo4?
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
stijndc
Mechelen - Belgium
Posts 35
stijndc replied on Fri, Apr 24 2015 4:50 PM
No. It doesn't work with my Lutron switch.
Graham
Liverpool
Posts 16
Graham replied on Fri, Apr 24 2015 6:59 PM
it should work with the B&O version of the Lutron devices
Michael
Sweden
Posts 2,578
Michael replied on Fri, Apr 24 2015 7:32 PM
The apple watch works with Lutron Big Smile
f5434964
Austria
Posts 206
f5434964 replied on Fri, Apr 24 2015 7:54 PM
Any idea where to buy lutron B&O Rania Dimmers? I'm from Austria and have trief to get in contact with Austrian and German Dealers but no response at all! Its incredible!!!
best Regards Elmar
Simonbeo
Posts 1,451
Simonbeo replied on Fri, Apr 24 2015 8:21 PM
Graham :
Sounds promising as we have the B&O version. That works with Beo4.
Simonbeo
Posts 1,451
Simonbeo replied on Fri, Apr 24 2015 9:18 PM
f5434964:
best Regards Elmar
I looked on the Lutron website . These were listed for Austria;
EGGER LICHT GMBH
OBERE TRIEBELGASSE 7
FELDKIRCHEN, 9560
004342765507
JOSEF NOPP KG
PASCHINGER STR. 111
LEONDING, 4060
+43(0)73268004067
www.nopp.at
f5434964
Austria
Posts 206
f5434964 replied on Fri, Apr 24 2015 10:02 PM
Thanks for your help:
Egger Licht - got an answer but no help at all
Nopp KG does not sell Lutron any more
Also contacted Megscon - but no response...
No help at all; Stb Brackets also sell Lutron; but I would need some help concerning installation...
Best regards Elmar
Simonbeo
Posts 1,451
Simonbeo replied on Fri, Apr 24 2015 10:15 PM
f5434964:
Best regards Elmar
If you're going to get Rania wall switches the installation is simple enough for any electrician . I bought from Stb and used our usual guy for the job.
Simonbeo
Posts 1,451
Simonbeo replied on Mon, Apr 27 2015 6:27 PM
The A9 keyring arrived today. And it works fine with the Rania!
knowing the power of the Beo4, it may even have enough IR  from outside in the front garden when we get home?
Simonbeo
Posts 1,451
Simonbeo replied on Sun, Jun 21 2015 6:16 PM
Fantastic news. We were leaving the house with my wife's car, which has A9 key ring, and my daughter had left the TV on. However ,as the IR works through the window , the TV could be switched off without unlocking the front door and going in to switch it off. Why did they discontinue this item ?
Simonbeo
Posts 1,451
Simonbeo replied on Sun, Jun 21 2015 6:45 PM
The A9 came in handy today when I realised our daughter had left the TV on after we'd locked the door. The IR does work through window glass !
Page 1 of 1 (12 items) | RSS
