Hi there, I have not posted for quite some time, so appolgies.
Can anyone help with an issue with a BG CD4500, It will play but has a lot of what can be described as "static noise" coming out, I can just hear the CD through the noise. The 33uf has been replaced with a blue Philips axial cap. And a check fro bad solder joints done too.
Any thoughts on this would be appreciated.
thanks
