Hi
Can anyone tell me where I can get these other than my local B&O store?
Cheers
Nigel
Have you tried Sounds Heavenly?
Thanks guys
I emailed Steve - he does not sell them but has recommended using brush wall plates that I'd never heard of before but look to be a very sensible and cost effective solution
Hi h1npw,
I used to sell the Powerlink wall plates but I was quite concerned over how fragile they appeared to be (in my view), plus I didn't like the fact that they added additional unnecessary connection points along the length of each speaker cable. I use the brush wall plates in my own home (http://soundsheavenly.com/hifi-av/128-brush-wall-plate.html?search_query=brush&results=1) as they allow the cables to pass neatly out of the walls, without any loss of reliability or sound quality.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
h1npw:Thanks guys I emailed Steve - he does not sell them but has recommended using brush wall plates that I'd never heard of before but look to be a very sensible and cost effective solution Cheers
vlohjr1:h1npw:Thanks guysI emailed Steve - he does not sell them but has recommended using brush wall plates that I'd never heard of before but look to be a very sensible and cost effective solutionCheersamen to that bought some from Steve and they are a great solution
BeoNut since '75
Eclipse 65V1-32Beosound M5Essence MK2BLI
elephant:What did you use for the in-wall channels / guides ? BeoNut since '75
vlohjr1:Not sure elephant my installer did it for me just used a metal detector and drilled some holes to chased them
Another alternative (if you don't mind a little soldering) is to purchase a blank plate from the same range as the rest of your sockets and switches and simply drill one or more (usually 18mm diameter) holes in them, then fit panel mount din sockets (the type with a thread and lock nut). This has the advantage of matching the rest of the faceplates in the room.
Kind Regards,
Martin.
