Hi!
I have this kind of setup: two Beolab 6000 active speakers, Beosound 3200 and my tv Panasonic TX-L42E5Y. So my question is, how can I connect these to as one system?
Hi and welcome to Beoworld.
The short answer is - you can't......not the easy way!
What you could do is to connect he headphone-out of the tv to the Aux-in of your BS3200.
However, mostly these outputs aren't the best soundwise and you will have the problem of dealing with two volume controls too.
Sometimes using the headphone-out disconnects the internal speakers - there might be a setting to change this with your tv?
Using the digital-out of the tv would require a 'Digital to Analog Converter' - which in most cases will introduce lipsync problems in the setup.
Mostly these digital-outs also are fixed-volume, which means, that you'd need to have a preprocessor (or DAC with volume control) in between, too.
Also please remember that the center speaker is rather important with video-sound.
You'd have stereo and - in best case - (compared to the BL6000) a weak tv speaker, which would have to be volume controlled seperately.
But - not all hope is gone!!!
Have a look at the socalled 'BeoPlay TV Connection Hub'.
There are several threads on Beoworld on this - try first here:
http://archivedforum2.beoworld.org/forums/t/16572.aspx
https://www.beoplay.com/~/media/ManualsPDF/S8/3511360_1507_multi_UG_BeoPlay-S8-MK-I-Master-4_Web_combine.pdf?la=en
You actually can use other BeoLab speakers - not just the S8 set!
Does the "BeoPlay TV Connection Hub" also work with the Beosound Moment; what do you need to make it work?
