Selecting / Adding VGA
This post has 1 Reply | 0 Followers
Calvin
Posts 182
Calvin Posted: Fri, Jul 10 2015 9:11 PM
Sorry, I'm maybe being really stupid here...
I just got a BeoVision 8 to replace a smaller computer monitor. I've plugged it in but I can't work out how to get the computer signal selected. I went into the menu and made AV3 set to PC + VGA.  Then I clicked the AV button at the top of my remote but nothing happened.  I'm wonderring whether the signal has changed over the years - the BV8 is a fairly new tv and my Beo4 is an older model, eg with with VTAPE as one of the buttons at the top.  Is this like Phono or NMusic where I need to add it to the menu and if so can someone remind me how to add AV3 as an option. Or preferably change, for instance, the SAT button to mean AV3
To be honest, If I need to access Phono and AV3 through the List menu, I'm tempted to treat myself to a Beo5.
Calvin
Posts 182
Calvin replied on Fri, Jul 10 2015 9:34 PM
My bad, you have to add PC as an option in the list menu
"To add PC as a source press standby (red dot) and list together. The display on the remote should show "add?" Press centre button on remote. Press right until display (on remote, not TV) shows PC. Press centre button again."
So I do now need AUX, PHONO and PC. I think a trip to get a Beo5 beckons.
Page 1 of 1 (2 items) | RSS
