Beolab 3500 wireless to existing setup?
Flere
Netherlands
Posts 345
Flere Posted: Fri, Jul 10 2015 11:30 PM
Hello all,
The following existing setup:
Main room: Beosound 4 with 2x Beolab 4 (and 2x Beolab 6000 in other part of that room).
Kitchen: Beolab 3500 connected via Masterlink to the Beosound 4
Now I would like to connect another Beolab 3500 in the study also to the Beosound 4.
But I cannot pull a masterlink cable.
The study is closer to the kitchen then to the Besound 4.
Is there a way to connect the Beolab 3500 in the study wireless to the masterlink step in the main/kitchen?
(FYI modernizing the complete setup is not an option)
Thanks.
- Flere
smile and enjoy the moment
Daniel
Svinarp, Sweden
Posts 1,632
Daniel replied on Sun, Jul 12 2015 6:48 PM
Yes, Beolink Wireless 1 is your solution.
http://www.beoworld.org/prod_details.asp?pid=1028
Daniel
Svinarp, Sweden
Posts 1,632
Daniel replied on Sun, Jul 12 2015 6:49 PM
Flere
Netherlands
Posts 345
Flere replied on Mon, Jul 13 2015 6:40 PM
Thanks Daniël.
I see that the Beolink Wireless has been phased out and is not available anymore.
So I will see if I can find them second hand.
I have no experience with Masterlink myself.
Is it possible to connect the Beolink Wireless at the already installed BL3500?
- Flere
Daniel
Svinarp, Sweden
Posts 1,632
Daniel replied on Mon, Jul 13 2015 11:08 PM
It's easy. Cut your ML cable and connect it again with a ML junction box. Here you also connect a new ML cable to one of the transmitter boxes for Wireless 1. If possible have it all hidden. Install the other transmitter box near your new BL 3500 and connect to it with a ML cable.
You find the manual for Beolink Wireless 1 at the B&O website (choose language before down loading):
http://www.bang-olufsen.com/en/customer-service/product-support/accessories/beolink/beolink-wireless-1
Stoobietoo
Exeter, Devon, UK
Posts 692
Stoobietoo replied on Sun, Jul 19 2015 10:09 AM
There are two things you'll need to check when you do this.
1. Ensure the Beolab 3500 is the wireless compatible version. Newer ones are. There are discussions on here giving the relevant serial numbers.
2. Ensure the Wireless 1's are both running the same software version or they will not connect to each other. I also think you need the later software to be compatible with the BL 3500.
stoobie
Page 1 of 1 (6 items) | RSS
