Beosound 4 Volume Issue
This post has 3 Replies | 0 Followers
LeonardMac
Posts 1
LeonardMac Posted: Wed, Jul 15 2015 9:45 PM
Hi there,
Apologies if this is an idiotic question to ask, but -
My dads Beosound 4 has suddenly developed a life of its own, and constantly decreases its own volume. For example, if we set it at volume 60, and watch it for 15 mins, its visibly decreases its volume by 1 every 30 seconds or so, until it is on volume 0. The display even shows its decreasing point by point.
Can anyone explain to me how to stop this happing? I've reached out to the B&O retailer we brought it from but have no reply. Any advice would be much appreciated!
parasound
Sweden
Posts 69
parasound replied on Thu, Jul 16 2015 2:19 AM
I had the same problem with my Beosound 4.
Remove the front glass, and turn it 180 degree (top become bottom)
Remove the power cord, slide the glass all the way up (same position when you load a cd )
and push it back with both hands (one hand at bottom, and one at the top) it will release smooth.
I hope it will help.
Living room: BeoVision 4-50 ACM, Beosystem 3 MK3 with samsung SP-H710AE projector, BeoLab 7-1, BeoLab 6000x3pair, BeoSound 3200, AV & CD cabinett & Beo4.
Lounge: BeoSound 3, BeoVision 7-32 mk5 & Beo4
Kitchen: BeoLab 2000 & Beo4
Master bedroom: BeoVision Avant-32, DVD1, BeoSound Ouverture & Beo4
Guest room: BeoVision 4002, DVD1, BeoSound 2000 & Beo4
parasound
Sweden
Posts 69
parasound replied on Tue, Jul 21 2015 8:47 AM
Did you get it to work?
Maybe someone can make a short video on how to do it, but i hope you did understand? :)
Regards
Marcus
Mindphaser
Posts 100
I'm wondering why this happens in the first place, i HAD a BS4 (swapped for a BS3200 which suits me better )....and honestly speaking the B&O build quality is not there anymore.
Just my 0,02 cents.
Page 1 of 1 (4 items) | RSS
