Dear all,
I have a question concerning the clock function on my beolab 3500. I attached it via ML to a beovision 8-40 and a beomaster 7000. The beovision is the master. First the timer function did not appear but now it is present but shows the wrong time. I have no idea how to correct this as I am not able to set the time in the menu of the beovision. The manual is unfortunately of no help...
The beolab 3500 is actually a LCS 9000 with SW. 1.1
Wouter
in BV8 and BV10 there is no clock function built in. The time displayed on your BL3500 comes from the BM7000.
So you might want to check the clock setting of BM7000.For this you have to set it to option 1 and use a 2way remote for setting the time.When you are finished set it to the previous option again.
BR,BeoMotion.
Thank you for the quick response! I will try that! Unfortunately my beolink 7000 is not working in two way mode anymore.. is it possible to set the clock with a one way remote?
No, I don't think that is possible.
I found my old beolink 5000 and although it is faulty, I managed to set the time as you described and it works flawless! Thank you very much!
Perfect. Glad that I could help.
