Beolab4000 flicks in and out
This post has 9 Replies | 2 Followers
jlagdon
Posts 5
jlagdon Posted: Thu, Jul 23 2015 1:27 PM
Hello all,
I have just "inhereited" a Beosound 9000,  Beolab 6000 and 4000 speakers. After setting up and trying everything out, I have found that one of the Beolab4000 speakers works intermitantly. The light flicks between red and green and the sound occasionally comes on for a brief period and then drops out again. I have swapped sides and it goes with the speaker. I believe this rules out cable or signal as the 6000's work fine.
I have checked the settings and they are correct, any advice or experiece of same fault. I am new to B & O and any advice gratefully recieved!
cheers
John
Dave Farr
France
Posts 2,283
Dave Farr replied on Thu, Jul 23 2015 1:46 PM
Welcome to Beoworld.
try removing the Powerlink cable from the back and use the second input.  Blow any debris from the DIN plug (at both ends).  A dodgy contact can cause issues.  The red/green LED is also an on/off button.  Try pressing it in a few times.
If that doesn't do any good, you may need it to be looked at by a repair shop.  It won't be a settings issue and will be a speaker issue.
Dave.
jlagdon
Posts 5
jlagdon replied on Thu, Jul 23 2015 1:59 PM
Thanks Dave,
tried that, made no difference... I guess its to the repair shop....
Cheers
John
Dave Farr
France
Posts 2,283
Dave Farr replied on Thu, Jul 23 2015 3:41 PM
Hi John,
there were some recent threads on the BL4000 and a relay was the cause of some problems.  If you search the forum you may find some useful info - especially before a repair shop tells you 'the amp is gone' etc.
Dave.
jlagdon
Posts 5
jlagdon replied on Thu, Jul 23 2015 5:46 PM
Hi Dave,
thanks for the suggestion, I am not an expert in electronics, vintage motorbikes are my thing. Logically the mute relay could be the cause, I will enquire to see what the B&O dealer thinks it will cost to repair...
Cheers
John
RaMaBo
near Munich
Posts 626
RaMaBo replied on Thu, Jul 23 2015 9:20 PM
Hi John,
this is a somewhat common failure arising with the age of the BeoLab 4000s. But it's not the mute relais but the small transformer for the standby circuit of the speaker.
It has one or more shortcuts in the winding on the secondary side which can lead to a complete 'dead' speaker. It can be exchanged by a good workshop or they change the complete standby module (less good because nore expensive Wink )
Ralph-Marcus
jlagdon
Posts 5
jlagdon replied on Fri, Jul 24 2015 11:42 AM
Thanks  Ralph,
I will get it checked out...
jlagdon
Posts 5
jlagdon replied on Fri, Jul 24 2015 12:21 PM
Is there any tests I can do at home tonarrow down the fault? Connect via line instead of powerlink ? Try regular stereo with no mains power? I might be grasping at straws of inexperience...
RaMaBo
near Munich
Posts 626
RaMaBo replied on Fri, Jul 24 2015 2:36 PM
Sorry there's nothing you can test before the Standby Transformer (or module) is changed. The standby circuit checks for a power on signal from the powerlink connector or by the line sense circuit which switches the power amplifier on and the LED from Red to constant shining Green.
Ralph-Marcus
Dave Farr
France
Posts 2,283
Dave Farr replied on Fri, Jul 24 2015 2:42 PM
I think it was that standby transformer that was mentioned in the other thread. Seems to be a common problem.
Dave
Page 1 of 1 (10 items) | RSS
