Hello,
I just installed my ne Beovision Avant 55. When I turn it on, it asks for a pin-code. It is the first the time, the Beovison is turned on.
Can anybody help me an tell me, what the first pin code is? I can't reach my dealer, because it is holiday in germany.
Thank you very much.
Mirco
MircoHH: Hello, I just installed my ne Beovision Avant 55. When I turn it on, it asks for a pin-code. It is the first the time, the Beovison is turned on. Can anybody help me an tell me, what the first pin code is? I can't reach my dealer, because it is holiday in germany. Thank you very much. Mirco
If the dealerr installed it - as they should, they should have given you the PIN! If they haven't, shoot them for shocking service. Are you sure you haven't got the PIN with the paperwork/invoice you have? You can only get it from your dealer according to the user manual.
Dave.
Get you started maybe, if you have a beo4(joystick version)
0 press left arrow and hold, 4* become 5* release and enter 1 5 times gets you into service mode, lasts 10 hours then need to do it again!!
I work on the KISS principle - Keep it Simple Stupid
One of my gripes about B&O products is the damn PIN code nonsense. Most of their speakers don't have any, and those are the most frequently stolen items. My television doesn't need a PIN code for theft protection, it already has a perfect theft deterrent system; 120lbs of weight!
BeoLab 5, BeoVision 7-55 MK2, BeoSound 5 Encore, BeoSound 9000, BeoLab Penta III, BeoLab 8000, BeoLab 6000, BeoLab 2, BeoLab 7-6, BeoSound 8, BeoTime (analog clock), Beo 4 remote.
Hungedu: One of my gripes about B&O products is the damn PIN code nonsense. Most of their speakers don't have any, and those are the most frequently stolen items. My television doesn't need a PIN code for theft protection, it already has a perfect theft deterrent system; 120lbs of weight!
You can disable it if you want. It's a deterrant from theft/resale but also keeps the kids off if you want! 120lbs is one big dog! I know what you mean. On the pallet, my 7_55 and stand were 180kg. No chance of moving that out of my house.
My gripe is against the shocking service from the installing dealer!
Stotty1111: Get you started maybe, if you have a beo4(joystick version) 0 press left arrow and hold, 4* become 5* release and enter 1 5 times gets you into service mode, lasts 10 hours then need to do it again!!
This is also called the 'burglar code'
my dealer helper me an I got the code.
is there a possibility, to reset the avant do factory setting and doing the first time installation again?
hi do you have a master code?
