Compatibility between beogram cd3500 and beomaster 5500?
This post has 3 Replies | 0 Followers
stentor
Posts 2
stentor Posted: Fri, Jul 24 2015 4:40 PM
Hi, I plugged the 7pin din plug from the cd 3500 into the cd input on the Beomaster 5500 but of course it did not work!! I always liive in hope! does anyone know the connections to the 7 pin plugs so that i could re solder them to make it work? Or is it not that simple! Hello everyone I'm a new boy of 84 had my first Beogram 1000 in the 60's after I had worked on computers for some years - valve of course! Now been retired for 27 years but still like to dabble- end of boring bit - Would be grateful for any info or where to obtain it.Regards to all John.
Lee
Newcastle upon Tyne UK
Posts 734
Lee replied on Sat, Jul 25 2015 12:14 AM
It should work fine. Maybe the cable is faulty?
Lee
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
It should work just fine.
Suggest you have a problem with your CD player or the DIN plug
Regards Graham
stentor
Posts 2
stentor replied on Sat, Jul 25 2015 7:11 PM
You pointed me in the right direction many thanks.So simple I'm   almost ashamed to tell you that I had plugged the cd into the gram socket - got disorientated looking from  above so everything was reversed except my brain which was in dumb mode -la vie est dure n'est pas! Regards John.
Page 1 of 1 (4 items) | RSS
