Beomaster 6500 - TIMER OFF displayed
This post has 4 Replies | 0 Followers
Andrew
Frinton, UK
Posts 917
Andrew Posted: Tue, Jul 28 2015 4:45 PM
Hi
My BM6500 is part of a link system - somehow I pressed something and TIMER OFF is displayed - I have tried to find out how to switch it off in the Master Control Panel and BM insructions but cannot find out how to do it - any ideas?
Dennis
Denmark
Posts 627
Dennis replied on Tue, Jul 28 2015 4:49 PM
Try holding in the 'MUTE' button on the BM itself and press 'STEP PROGRAM'. Smile
kallasr
Germany
Posts 2,562
kallasr replied on Tue, Jul 28 2015 4:50 PM
Found this:
The left and right buttons pressed simultaneously activates/deactivates the timer function.
Best regards
Ralf
Andrew
Frinton, UK
Posts 917
Andrew replied on Tue, Jul 28 2015 6:03 PM
Perfect, thanks, the light is now off thank goodness
Thanks again for the fast reply
Andrew
Anders Jørgensen
Denmark
Posts 350
Reminds me of my first Beomaster 6500.
It was in an auction and description saying dead speaker outputs kept the bidding fairly low. I did some research and did not find the 6500 to have those kind of problems but I knew Martin would not mind anyway.
I won and it came home by arranged truck one evening. I set it up and Timer Off in the display on the Beomaster. I knew that Timer off mutes the speaker out puts and so on to hold to the right front and tap on the left which removes this message according to the user manual and it did. I had sound from both channels though right one sounded bad and it was but that is another story.
Page 1 of 1 (5 items) | RSS
