Beolab 18 compatible receivers
This post has 1 Reply | 2 Followers
rolantos
Posts 1
rolantos Posted: Thu, Feb 13 2020 12:52 AM
hi all,
i will be thinking of getting a set of beolab 18 speakers. i was wondering if what will be kind of av recievers will be recommended as i will expanding to 5.1 in the near future
rolantos
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi rolantos,
Welcome to Beoworld!
You can use Beolab speakers with any AV receiver that has volume controlled RCA pre-out sockets fitted.  Receiver model numbers seem to change on a weekly basis, but as a starting point I would suggest looking at the Pioneer SC-LX59, Denon AVR-X3600, Yamaha RX-A830 or RX-V775 AV processors/receivers, all of which have audio pre-out sockets for easy connection of Beolab speakers for a Dolby surround sound setup.
Please click on my sponsor link below if you need any help connecting the speakers and I will be pleased to assist!
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Page 1 of 1 (2 items) | RSS
