Hi! I have an Essence conected to my home network.
When I play a video file on my iMac the sound delivered from the Essence is ± 2s delayed.
Annoying as I cannot watch movies or concerts ( I have to switch to internal speakers instead of 12.2:)
Thanks for help!
If you use the AUX input there will be no delay,
Also if you use VLC you can make sound delay so it fits.
