How to you set on volume level on a Beomaster 6500?
This post has 1 Reply | 0 Followers
Mdyarnell
Posts 12
Mdyarnell Posted: Thu, Jun 21 2012 2:13 PM
When I switch on my Beomaster 6500, the volume defaults to like 60 which is blaring, there must be a way to set this lower like on other models. Does anyone know how?
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
Set the required volume level with the remote then press STORE  STORE
If the Beomaster does not remember this after mains off/on then it is likely that the Lithium battery needs replacing.
Regards Graham
Page 1 of 1 (2 items) | RSS
