Dear DLNA users,
I'm facing an issue with the B&O App when I want to move forward/backward within a DLNA track as shown in the following video: https://www.youtube.com/watch?v=_EaZngKX9h4&feature=youtu.be
I have the problem with Twonky, Minimserver and PLEX, independently of the target B&O product (Core,M3,M5,A6, etc..), independently of the IOS hardware used (not tested with Android) and the problem exists since a while, even if it was solved at some point versions ago, it came back.
B&O support claims they have not been able to reproduce the problem, which I can admit.
I would like your feedback please, including if it works or not for you, which DLNA server has been used, which B&O product and which version of the B&O app on which platform (IOS, Android, iPhone, iPad, other)
Many thanks in advance!
Carolpa:Just first quick test: mostly backwards and forwards are doing as expected. Once in a while on forwards a jump of some seconds. Test environment: Minimserver, iPhone, Beoplay A6, BS35.
Thanks! I noticed that the jumps occur more frequently when you move the cursor between 0 and half of the length of the track.
