6-26 TV AV1 / AV2 input question.
Lightbulb42cd
Posts 1
Lightbulb42cd Posted: Fri, Aug 28 2015 7:44 PM
Hi, hope this isn't a stupid question, we have a Beovision 6-26 TV; obviously the terrestrial TV side of is no longer working here in the UK, but we have used it for a while with a Thompson decoder plugged into the AV1 input - works a treat.
We have now purchased a NowTV digital streaming device which I have plugged into the AV2 port on the back.
I have used the menu / options / connections menu to tell the TV it now has a DVD player linked to the AV2 port - but I cannot find out how to change from AV1 display to AV2 display.  There's no 'source' button the remote as you'd find on 99% of TVs.
Any help would be appreciated.
Andy,
graemeben
Posts 132
graemeben replied on Fri, Aug 28 2015 8:31 PM
Hi. Do you have a Beo4 remote? If so you will need to add the AV2 command to the remote. If memory serves me well you press list and stand by together then add? appears on the screen. Press go then scroll through the list until AV2 appears and press go again. Should be added to the list button.I haven't done this for a while and I'm working from memory but hopefully this is corrrect.
Graeme.
Andrew
Frinton, UK
Posts 917
Andrew replied on Sun, Aug 30 2015 10:46 AM
If you are using a blink 1000 maybe try and set AV2 to V.Tape/V.Mem or STB and then press VTape -or Sat
Page 1 of 1 (3 items) | RSS
