Beomaster 2400.2 remote
Piaf
Victoria, British Columbia Canada
Posts 2,639
Piaf Posted: Thu, Aug 27 2015 3:14 AM
Is there a B&O remote control unit that will work with a Beomaster 2400.2 that has a TAPE function?
I assume that this early original remote is unique to the Beomaster 2400.2 and that all subsequent remotes are incompatible.
I only ask because I so thoroughly enjoy my Beomaster 2400.2 and corresponding Beogram 4004 with their remote capability that it would be fantastic if I could get the BM 2400.2 to select my Beocord 8004.
Sure, this is probably another stupid question, but let’s assume for one moment that there IS a remote that would work, the stupid thing would be not to ask the question in the first place.
Jeff
Beogram 4000, Beogram 4002, Beogram 4004, Beogram 8000, Beogram 8002, Beogram 1602. Beogram 4500 CD player, B&O CDX player, Beocord 4500, Beocord 5000 T4716, Beocord 5000 T4716, Beocord 5000 T4716, Beocord 8004, Beocord 9000, Beomaster 1000, Beomaster 1600, Beomaster 2400.2, Beomaster 2400.2, Beomaster 4400, Beomaster 4500, Beolab 5000, Beomaster 5000, BeoCenter 9000. BeoSound Century,  S-45.2, S-45.2, S-75, S-75, M-75, M-100, MC 120.2 speakers; B&O Illuminated Sign (with crown & red logo). B&O grey & black Illuminated Sign, B&O black Plexiglas dealer sign, B&O ash tray, B&O (Orrefors) dealer award vase,  B&O Beotime Clock. Navy blue B&O baseball cap, B&O T-shirt X2, B&O black ball point pen, B&O Retail Management Binder
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Aug 27 2015 6:18 AM
No.
The Beomaster doesn't support "remote control" for Beocords and there are no compatible Beocords either.
Peter
Earsdon
Posts 11,991
Peter replied on Thu, Aug 27 2015 10:17 AM
The 2400 only has a 5 pin DIN connection for the Beocord and it uses a very primitive language compared to Datalink. The Beomaster 4500 has similarities in looks and is more advanced with communication - the Beocord actually is the same height, unlike the Beocord 2400. Or go for a Beomaster 6000 or 8000 and match the Beocord you have. I do like the 2400 though - my first B&O!
Peter
Piaf
Posts 2,639
Piaf replied on Thu, Aug 27 2015 4:08 PM
Thanks Martin and Peter.
I was 99.999% sure that would be the case. Doesn’t take away in the least the “cool” function of the Beogram 4004, but just to be able to select the Beocord would have been nice.
Jeff
Søren Mexico
Mexico City
Posts 6,411
Piaf:
Jeff
I f you think about it it is not a bad thing, you will have to leave your chair once in while, not to speak of less blisters on your fingers, at least you can use the remote to manage volume, and change to Radio or Phono if wanted when the BC is playing, some of BCs will power off by itself after tape end.
Piaf
Posts 2,639
Piaf replied on Thu, Aug 27 2015 5:31 PM
Good grief Søren, you are BAD! BAD.
The real benefit of the 2400.2 remote control is that I don’t need to touch the aluminum “buttons” on the Beogram 4004, which discolor with usage over time. As mentioned previously I “cheat” by using a cloth which avoids any contact with the oil on our skin. However with the remote I don’t even have to touch the dustcover, just press P and away the 4004 goes like magic.
And yes indeed, the Beocord 8004, delight unit that it is, turns itself off after a bit.
Jeff
Page 1 of 1 (6 items) | RSS
