Beocenter 6-23 mk II (Type 9219 - 9225) ?
riverstyx
SouthWest UK
Posts 938
riverstyx Posted: Fri, Sep 25 2015 6:35 PM
Does anyone have a pdf copy of the service manual for this TV in English? There's none for this model on beoworld and searches on google have so far only turned up copies in Danish.
The 6-23 from our bedroom this morning decided it would no longer turn on. Red standby light is on, but does not flash when a button is pressed on the remote, even when trying to set v.opt. I've checked the obvious - I left it switched off at the mains whilst at work today and tried it again this evening and I've obviously checked the beo4 is working elsewhere in the house.
I'll going to start by examining the IR receiver / autocontrast board and the power supply, but if anyone has any other thoughts or can provide me with a copy of the service manual that would be very useful.
If I can't repair it, it will likely end up as a donor set as it's not likely to be cost effective to replace the chassis unfortunately.
Kind Regards,
Martin.
Page 1 of 1 (1 items) | RSS
