Beolab 3500 display dead
f5434964
Austria
Posts 206
f5434964 Posted: Wed, Oct 14 2015 11:41 AM
Hello!
I've got a Beolab 3500; now after installing it the display kept dead - no red dot or anything that would give a sign of life.
The manual says that there are 2 buttons - mute and timer -> but there seems to be no reaction...
I do not think that there is a pin protection?!
Any ideas despite contacting my dealer?
Thanks, Elmar
Millemissen
Flensborg, Denmark
Posts 14,680
Hi Elmar,
how is your BL3500 linked up?
More details, please?
f5434964
Austria
Posts 206
f5434964 replied on Wed, Oct 14 2015 2:28 PM
Hello MM!
Thanks for your quick answer!
The BL3500; Type 1601, Item 1160112; Serie 20xx was unplugged over some days; before it was said that it worked
I plugged in ML (cable) and Mains without any reaction of the BL3500 - I expected that somewhere a red light will get on but the display was dead
in the manual it says there are 2 buttons as well - but trying to use/push them (timer/mute) was not very successful
so: is there a fuse, something small to check?
will there be a the red light without ML?
Elmar
Page 1 of 1 (3 items) | RSS
