Beovision 7 40 mk 5 ,beovision 6x3, beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2, 5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
Hm, what was wrong with your BS3? The touch panel?
Goodness! I don't think I have anything as new as a BS3!!
Peter
Made my day. My touch pad on the top has just stopped working too so I'll also have to get creative.
Dave.
this product was a real disaster!
creative solution... but sad on the other hand.Are touchpads still availabe? Battery is the smallest problem. Maybe some of your genius users here (Yes, I'm looking at you, Beomotion, Pinter75, Beojeff etc.!) :-) are able to offer a replacement solution. Perhaps a mechanical wheel instead of the touch wheel....
TWG:Are touchpads still availabe? Battery is the smallest problem. Maybe some of your genius users here (Yes, I'm looking at you, Beomotion, Pinter75, Beojeff etc.!) :-) are able to offer a replacement solution. Perhaps a mechanical wheel instead of the touch wheel....
Half a year ago they were still available...
Do you mean something like this? http://ecx.images-amazon.com/images/I/71hi5tvmzYL._SL1500_.jpg
Would be possible but requires either a second MCU or some SW hacking if you want to keep the original functionality.Will get back to this if there comes the day my BS3 isn't working any more... ;-)
