Essence wall
This post has 19 Replies | 3 Followers
Seanie_230
UK
Posts 2,278
Seanie_230 Posted: Sun, Jun 28 2015 1:48 PM
Hello all
I have today been configuring my essence remote in automation mode so I can control my moment room.
I don't know if this is normal but the turn part of the essance is almost impossible for me to turn.
Is this normal or is there a setting to reduce force needed.
It has always felt quite tough but now it is very very tough and I cannot turn it without. Force.
Any thoughts?
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Dave Farr
France
Posts 2,283
Dave Farr replied on Sun, Jun 28 2015 3:26 PM
The plate it's in must be the problem. Mine is just on the wall without a plate and the wheel virtually spins if I blow on it - it's that free and easy to turn. There is no resistance at all.
Dave.
Seanie_230
UK
Posts 2,278
Hi Dave cheers
When I take him off the wall it's still very tough.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Dave Farr
France
Posts 2,283
Dave Farr replied on Sun, Jun 28 2015 5:44 PM
Seanie_230:
Hi Dave cheers
That's not right then is it?  Has it been OK before or has it always been stiff to turn?  As I say, mine's effortless and silky smooth.  This stiffness problem has been raised in another thread I think but seemed to be isolated.  It will still be under guarantee so I'd take it to your dealer and get him to look at it. A rogue bit of dirt or dust may be the cause and a simple procedure may clear it.
Dave.
Seanie_230
UK
Posts 2,278
Cannot find the thread anywhere I will talk to my dealer in the morning too
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
mjmedlo
Posts 922
mjmedlo replied on Sun, Jun 28 2015 6:54 PM
There's a recall on that problem.
Check your dealer.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Sun, Jun 28 2015 8:08 PM
Maybe it doesn't like your taste in music and is being passive aggressive about it? Crying
Jeff
Seanie_230
UK
Posts 2,278
Maybe Smile
I did wonder why he has being so tough
Recall it is
SmileSmile
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
Afternoon all
I spoke to my dealer today and he ordered me a new one as per the recall procedure.
Does anyone know what this happens on what happens if it happens again after the warentee runs out.
thank you
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
Afternoon all
thank you
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
BeoMegaMan
Posts 601
You can take apart the remote and remove a rubber gasket that surrounds the wheel. It is most likely already wrapped around the wheel and ground into it preventing the wheel from moving freely. If your dealer allows you to keep it, you can remove the gasket and it will spin freely again and be able to use it once again without issues.
Ah, you know... A little B&O here, a little there
TWG
Posts 1,672
TWG replied on Mon, Jun 29 2015 5:30 PM
BeoMegaMan:
Will it rotate with the same resistance as originally intended or is it very sensitive/loose after removing that rubber gasket? Are there pictures/videos of the Essence innards?
BeoMegaMan
Posts 601
TWG:
BeoMegaMan:
It should rotate looser than originally intended. Some like it more, some like it less. I have seen a few that maintain their factory level of resistance, but most likely due to the fact that there was rubber gasket still stuck somewhere in rotation.
Seanie_230
UK
Posts 2,278
Well my replacement is ordered.
This will be fun until the next time it locks up.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
BeoMegaMan
Posts 601
Seanie_230:
You shouldn't have anymore troubles. Production has corrected the issue. Take apart your current remote, remove the shredded gasket and enjoy a secondary remote. :)
Seanie_230
UK
Posts 2,278
Today I looked at the active round wall plate for solid wall and drywal. The solid wall is deeper and more expensive for some reason.
Stb sell a convertor to use the essence on the active backing plate.
Anyone used a normal drywall one as I could only knock off plaster in a circle rather than take big chucks of brick out.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
Hello all
can anyone tell me how to actually open the essence wall remote to remove the gasket i cannot see how.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
Anyone? I cannot find a service manual telling me how to take it apart to remove the broken gasket.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Seanie_230
UK
Posts 2,278
hi all
did anyone know how to open the essence wall remote as I cannot work it out
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
beoandy
sissi not kangaroo
Posts 329
beoandy replied on Wed, Sep 16 2015 11:15 PM
hi seanie!
did you found a solution to disassemble the remote?
BS Ouverture, BS 9000, AV 9000, Avant 32 DVD, BV9, BV6-22, BS 5, BS 4500, BS 7000, BC 9500, Beo6, BL Penta, F1000, BLGW, etc....
Page 1 of 1 (20 items) | RSS
