Eclipse 65V1-32Beosound M5Essence MK2BLI
Hi seanie,
Mine is still on 1.4.1, no update (on a sunday?)
Is your gateway & DNS servers correctly filled in on the system/network tab?
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
Ah, you know... A little B&O here, a little there
Could I be of help with the setup manual:
https://www.dropbox.com/s/gle62x40f71oz7s/BLC_NL-ML%20Installation%20Guide%20Ver.%201.2.pdf?dl=0
Hi Seanie_230
There was an update yesterday of the BLC, its now on software 1.4.2.19611
Chris:Hi Seanie_230 There was an update yesterday of the BLC, its now on software 1.4.1.19611 This software update includes various performance improvements and minor bug fixes as well. "Believe nothing you read and only half of what you see, let your ears tell you the truth."
BeoNut since '75
Sorry, spelling mistake. It must be update with number 1.4.2.19611 for sure.
It fixed my track choosing problem on the ML also, I can use again the Beo4 up-down button to choose a music track.
