Hi
I have the two above connected as part of a link system, there is also a BV6-26 and BL2000 - when I select an audio source on the BV8 it seems to take forever, if it all for the sound to come through - in the link rooms it is instant, if I change audio sources from the BV8 it happens straight away in the other rooms but not the room the BV8 is in - anyone had this and can point me in the right direction - or as the module in the BV8 is an add on is that just normal? I seem to remember it was also slow in my old house so have eliminated the wiring as a cause.
Andrew
