Beovision 7 40 mk 5 ,beovision 6x3, beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2, 5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
Cut of the connector of your MK2 cable and solder on a short MK3 cable with connector on your existing wires.You need to connect the blue wire (data ground) to the normal ground, too.Then most of the buzzing should be gone.
