Hello Beoworld!
My left tweeter on my Beovision Avant 32 is not working any more, and i wonder if anyone have one just laying around?
If someone could help me, i would appreciate it very much
Thanks for reading
//Marcus
Living room: BeoVision 4-50 ACM, Beosystem 3 MK3 with samsung SP-H710AE projector, BeoLab 7-1, BeoLab 6000x3pair, BeoSound 3200, AV & CD cabinett & Beo4.
Lounge: BeoSound 3, BeoVision 7-32 mk5 & Beo4
Kitchen: BeoLab 2000 & Beo4
Master bedroom: BeoVision Avant-32, DVD1, BeoSound Ouverture & Beo4
Guest room: BeoVision 4002, DVD1, BeoSound 2000 & Beo4
Marcus,
Your previous post was deleted (and this one edited) because we kindly ask members to upgrade to atleast silver membership level to place sales/wanted ads.Beoworld will appreciate your support.MartinBeoworld moderator
And I see Marcus is now a Silver member - well done.
Have you tested the speaker off the TV to make sure it is the actual speaker that is the problem and not something else?
Dave.
Yes, now its silver
I have disconnect the tweeter, and its not working, tried another tweeter (not B&O) and it was working perfect, but did not sound as good
Or do anyone know a tweeter that will sound almost the same.
I could change the both of them if necessary
I think they might be a Peerless tweeter if that help.
Occasionally, the same drivers can be found in other models, speakers etc.Have you checked ?
Thats a good idea!
I think that Beolab 6000/8000 share the same tweeter. But people usually fix Beolab speakers, but not there old Avant´s
Maybe someone have a Avant thats not working, and are willing to sell me the tweeters?
I may be able to help. I have 2 redundant Avants and as CRT's are worthless these days - despite their superb picture, I could strip one of them that's been in storage for a while. I'll have a look later to see how accessible it is. Send me a PM with your address.
Hello Dave!
I have send you a email
Marcus, I'm taking it out now. I'll post it asap - hopefully tomorrow.
And just to confirm, the grey lead is to the black terminal and the white lead to the clear/transparent terminal on the tweeter. Hope it works out OK. Any problems, let me know (I have another on the other side!).
Hi Dave!
The tweeter has arrived, and it works perfectly
I will also make a donation to Beoworld.org
Thanks again
I have now done a donation to Beoworld.org
