I have an existing Beomaster 7000 system with CD and Cassette deck, recently been looking for a turntable to complete the system, I was able to acquire a Beogram 3300 turntable from Ebay but have not received the unit yet. My question is, does the 3300 turntable work with my 7000 system?
The 3300 does not have the RIAA amplifier as standard, and neither does the bm7000..
So you need an external riaa amplifier to get it working together. The bg3300 has datalink, so it can be controlled by remote.
There is a retrofit RIAA amp available for the bm7000, but that is very rare.
The 35/45/65/7000 beograms has RIAA built in.
/Weebyx
thanks for the clarification!
will this device make it work?
http://www.ebay.com/itm/BeoGram-RIAA-Pre-Amp-Cables-for-Bang-Olufsen-B-O-BeoSound-Mk2-/151984343674
the pre-amp is only for sound, but for remote-control, you have to use also the 2 extra pins of the DIN-plug. (Datalink)
