Encore and loewe tv
Eddegroot72
Posts 58
Eddegroot72 Posted: Tue, Jun 26 2012 6:43 PM
I am planning to buy an b&o encore ( replace linn ds and linn pre-amp) and connect my tv out (2xrca) to the line in on the encore (3,5mm)
I heard that there is a time delay on the line in. My Loewe tv has a sync (view/sound) possibility of 100 ms plus/min.
I was wondering if this could work. I sold my linn ds already which was connected with my pre-amp so I need advice!
Hope to hear from you guys.
srm
Germany
Posts 74
srm replied on Tue, Jun 26 2012 7:18 PM
The "solution" is  the almando multiplay.  But be carefull:  It only works correctly when your Loewe has the inbuilt Surround-Module with the Switch Voltage.
I have the Encore too, and a Loewe Xelos without it. So i had always The "PLOPP" at my Labs when i turn on/off thr TV.
 And believe me: Thats no solution. So i will/must upgrade to a BV
Greets Sven
BV10-46 -  BL8002 - BL 19 - BeoPlay A1 - Beo4 - BeoRemote One  -  3x Beotime - Beotalk 1200 -  Beocom4 - Beocom 2 (Yellow, Alu) - ATV2 / 4
Page 1 of 1 (2 items) | RSS
