Interested in " Moment" but using Marantz receiver
This post has 9 Replies | 0 Followers
Tifoso48
Posts 162
Tifoso48 Posted: Tue, Oct 20 2015 3:52 AM
My current set up:
Beolab 18, 19 + 15 (ceiling mounted as rear speakers), 4000  in zone 2 - all connected wirelessly via transmitter 1 - connected to Marantz receiver.
I would very much enjoy adding a "moment" however, I was told that the only way this could work would be to connect the moment to my Marantz and assigning an input. This then would mean I would have to turn on the Moment and then turn on the Marantz.
This in my opinion would defeat the purpose and I might as well use the Deezer on my i-phone and air-play it via my playmaker.
Am I overlooking the obvious? Is there a way of connecting a Moment so that it was instant on like it is meant to be?Confused
kallasr
Germany
Posts 2,562
kallasr replied on Tue, Oct 20 2015 5:30 AM
Maybe an Almando switch would help.
Ralf
Millemissen
Flensborg, Denmark
Posts 14,680
Tifoso48:
If the receiver/preamp, that you are using, has 'autosense' on its line-in connection, this will work.
Your Marantz probably hasn't....
Chris
Ostend-BE
Posts 1,170
Chris replied on Tue, Oct 20 2015 8:20 AM
Actually, I'm scratching my head now.
Why using further the Marantz as a receiver, if your planning to buy the Moment. The Moment gives you all your older Marantz has, internet HQ radio, Deezer and the opportunity to connect line-in.
You have BL 18 + 19 included Wisa...
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
Millemissen
Flensborg, Denmark
Posts 14,680
Probably because of the "4000 in zone 2" - as described above.
That is a feature of the Marantz.
Tifoso48
Posts 162
Tifoso48 replied on Tue, Oct 20 2015 1:44 PM
it is not just about zone 2 which is important because the 4000's are in the dining room part of our " Great Room".
There is also my new high end Samsung TV - which is connected to the Marantz and also my Blue ray/CD which get fed into the Marantz and then via the transmitter 1 to the speakers.
I did note on the back of the transmitter 1 another place for "input", and not being a technical person I am wondering if the Moment was plugged into that and so, if the receiver is off the only source would be the Moment - but I am sure that is just wishful thinking.???
Tifoso48
Posts 162
Tifoso48 replied on Tue, Oct 20 2015 2:10 PM
One last piece that is important to know.
In addition to the speakers mentioned I utilize a Definitive Technology Center Speaker to generate a really nice 5,1 surround sound for which I need an av receiver because of lack of B&O TV.
Millemissen
Flensborg, Denmark
Posts 14,680
How are the sound channels connected to the Transmitter 1?
And how is zone 2/BL4000 connected? Do you have a second Transmitter for that, or are they hardwired?
Note: anything connected to the input/s of the Transmitter 1 can only be heard on the speakers connected to that transmitter 1.
Tifoso48
Posts 162
Tifoso48 replied on Tue, Oct 20 2015 6:54 PM
Marantz has a separate zone 2 pre-amp out which is connected to slot 3 on the back of transmitter 1. When I want to listen to music there I turn on zone 2 on the Marantz via their remote control - so no, there is no separate transmitter 1.
the 18, 15 + 19 are slots 1,2,4 and are connected to the pre-amps for the various inputs sources of music.
Jurgen
Tifoso48
Posts 162
Tifoso48 replied on Wed, Oct 28 2015 8:04 PM
So, there is an important update and I want to specifically thank the team at B&O USA for creativity and testing.
The Moment can be connected with RC cable directly into the back of the Transmitter 1 and all speakers connected to Transmitter 1 will fire up.
If at any point you fire up the receiver, it will shut off the signal coming from the Moment - which has second priority.
As I have pointed out in my particular set up I have a second zone and if I did not want music to go there I would have to physically turn off the 4000 - not a big deal because they have on/off buttons.
The only other downside is that it would be impossible to have different volume in zone 1 and zone 2.
Net, net I am glad there is a viable alternative and I will now have to think if this is what I want to do.
Page 1 of 1 (10 items) | RSS
