I managed to repair almost all problems on my Beocenter 9500, however the CD is not working.It spins but no readingl....
Any idea where I can find a replacement for it ? I live in Canada!
Thanks in advance!
Good morning,
When I do repairs on my equipment (B&O or other), I habitually order the parts from Digikey. The only inconvenient is that the shipping costs are high if you order just a few parts. But the delivery time is very fast (1 day or 2 max). Normally, I order some other stuff (tools, solder, etc) at the same time.
For the capacitor, you must get a Vishay or BC Components branded one (they acquired Philips passive components division some years ago). Apparently, the circuit has very tight tolerances for that capacitor and will not work if another brand is used.
Good luck,
Jean
