P30 tweeters dead
This post has 4 Replies | 2 Followers
Henry
South Africa
Posts 17
Henry Posted: Sun, Oct 18 2015 7:00 AM
Hi, I inherited two P30s from my dad and only fired them up for the first time in 15 years. They look ok but both tweeters are clearly dead. I opened them up but cannot find any obvious problems. I have limited electronical experience so don't want to fiddle too much without advice. Please help. Henry.
Rich
Orlando, Florida, USA
Posts 2,598
Rich replied on Mon, Oct 19 2015 7:46 PM
I think P30s share a tweeter with M70s and P45s (I have a pair of each). The voice coil lead attachment to the terminal is very delicate. I have seen it break when the terminal is twisted. That failure mode is repairable (I've done it).
On the other hand, a failure in the crossover could also be the problem.
The P30 is a wonderful, overlooked little speaker. I wish I had a place to hook mine up. Definitely worth putting some time into fixing if you want a wall mounted speaker.
Where are you located?
Henry
South Africa
Posts 17
Henry replied on Mon, Nov 2 2015 3:34 AM
Hi, sorry for the late reply, I am in South Africa.
i am happy to go digging in there, nut I need some guidance as to what I am looking for.
Thanks, Henry
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Nov 2 2015 6:52 AM
I have a few good used tweeters in the drawer if repairs fail.
http://beoparts.com/2014/07/16/beovox-dome-tweeter-2/
Rich
Posts 2,598
Rich replied on Mon, Nov 2 2015 4:23 PM
Henry:
Well, then it wouldn't be practical for you to send them to me in the USA to try to fix them.  Go ahead and buy from Martin.  You won't be disappointed.  Replace the capacitors in the crossover while you're in there.  Martin can probably help there also.
A first step in checking the driver, if you have an ohmmeter, is measure the drivers' DC resistance.  The DC resistance should be around 4 ohms.  If the terminal leads are broken, you won't be able to measure (or it will be infinite, I suppose).
It really isn't all that hard to fix a loudspeaker.  You basically just take it apart and put it back together, replacing any defective component along the way.  Here are a couple threads to give you an idea.
P45 Rich
M70 Soren
Page 1 of 1 (5 items) | RSS
