Hi!
I've recently bought the S8 Connection Hub for my BeoLab 18 pair.
The connection looks like this:
S8 to (one) BeoLab 18: RJ45 to RCA (l/r)
Toslink between the BeoLab 18's.
Due to the RCA cables, I can't close the front lamella properly on one of the speakers. Seems like the RCA cables go too much out, and therefore the magnet won't work properly, and it looks bad.
Anyone experienced the same problem?
Sounds strange. There should be a lot of room for the cable via the hole at the back of the speaker.
Can you provide an image of how it looks?
Sorry, didn't see this post until now. The problem was solved, just had to push the lamellas a little bit more.
