Beosystem 3 flashing white/strobe
This post has 1 Reply | 0 Followers
Ryan
Sarasota, Florida
Posts 5
Ryan Posted: Sat, Nov 7 2015 12:50 AM
while playing any game on my PS4 my Beosystem 3 goes nuts. Every minute or so the screen will strobe white and then return to normal. Lowering the contrast seems to limit the intensity of strobe. I am running the hdmi in to hdmi out via a dvi to hdmi adaptor. Projector is a benq1075. This issue only exists when the PS4 runs through the beosystem 3. Any ideas? Thanks!
jvezina
Montreal, Canada
Posts 200
jvezina replied on Sat, Nov 7 2015 3:16 PM
Good morning,
Could you check the version of the software in it ? Early versions (4 or less) had a problem handling the video input of some sources.
Best regards,
Jean
Page 1 of 1 (2 items) | RSS
