Cleaning Contacts on a Beomaster 6000 Quad Remote Commander
This post has 1 Reply | 0 Followers
Manbearpig
Posts 908
Manbearpig Posted: Wed, Nov 18 2015 9:09 AM
Dear members,
after buying a Beomaster 6000 quad, which appears to be fully operational, I discovered that some of the buttons on the remote are not working. Somebody gave me the hint that cleaning the inner contacts might help. So I opened it up and just blew a couple of times beneath the circuit board and immediately after that everything was working ok.
However, I'd like to give the contacts a better clean since it's still not optimal. This seems problematic without removing the circuit board from the metal part of the commander because you can't reach contacts properly otherwise. But how do you do that without breaking anything? How do you clean these contacts?
Thanks!
Kai
Manbearpig
Posts 908
No idea?
Page 1 of 1 (2 items) | RSS
