How to activate y pb pr on Beovision 7 Mk I
This post has 1 Reply | 0 Followers
Pagoda66
Posts 1
Pagoda66 Posted: Tue, Nov 10 2015 5:12 PM
Hi
I have been trying to connect apple tv 3 to my Beovision 7 Mk I with no luck. I have tried Hdmi / Dvi adapter but the picture is always blinking. I bought adapter to convert hdmi to component RGB ( Y Pb Pr) and audio, the audio works but I can not find the Y Pb Pr in the settings menu on my tv.
So my question is : How can I activate Y Pb Pr input on my Beovision 7 in AV-4 ? I can only choose between NONE and PC
I would appreciate all other ideas.
Regards
H Bald
Raeuber
Germany
Posts 2,542
Raeuber replied on Tue, Nov 10 2015 5:57 PM
Y Pb Pr is not available in all AV menus. At my BV 7 Mk 6 it can only be assigned to AV2 and AV3. I don't know which AV you can use with Mk1.
Hope this helps.
Regards
Räuber
Page 1 of 1 (2 items) | RSS
