Beocenter 2 with Beovision 10
Kevin Waldron
Orange County, California
Posts 20
Kevin Waldron Posted: Sun, Nov 15 2015 10:15 PM
Hello there,
I have a Beocenter 2 connected to a Beovision 10 through a SCART cable, yet when I set DVD SCART output to RBG, I get a very blue/green picture. The color issue resolves when I set it to s-video (y/c) output, but of course the quality of picture is diminished. Any thoughts on how to resolve this?
kallasr
Germany
Posts 2,562
kallasr replied on Sun, Nov 15 2015 10:48 PM
Maybe not all AVs / Scart-connections are capable of RGB. Did you try all scart inputs? I assume your cable is of good quality.
Kevin Waldron
Posts 20
I have confirmed that the AV socket is RGB compatible with another DVD player, the DVD 1 which I have set to RGB (and Region 2 for Danish movies.)
The SCART cables I'm using work fine.
Kevin Waldron
Posts 20
On further investigation, I found that the SCART protocol carries connections for both RBG and Y/C. It uses the same pin 15 for both signals (the suspected bad pin hence the blue/green picture). It carries the Red "up" signal when in RBG mode, and the Color "up" when in s-video mode. Since the s-video color signal works fine, it can't be a bad connection or faulty pin.
However, SCART can also switch over to component video with Y/Cr/Cb. I wonder if the BC2 is outputting RBG and the TV is trying to receive Y/Cr/Cb? Or vise versa?
Any thoughts on how to resolve?
Page 1 of 1 (4 items) | RSS
