One of the selling points of the newer headphones (H6/H8) are the replaceable pads and cables. I see that you can buy the cables from B&O on their website (found it somehow) - but I can't seem to find a link to buy replacement pads????
I have the tan colored ones - which I love - but are getting a little dirty......
thanks
-michael
Mine fell apart about 18 months into use, and cost £40 to replace.
Chris Townsend:Mine fell apart about 18 months into use, and cost £40 to replace. Beovision 7-55 Mk2, Beovision 8-32, Avant RF 28, Beolab 9, Beolit 15, Beoplay A2, Beocom 2, Beotime, H6, Form 2.
I have been wearing my H7 almost every day and I have to say its the best purchase I have made for a long time.
They are perfect in any way :)
Fatandre:I have been wearing my H7 almost every day and I have to say its the best purchase I have made for a long time. They are perfect in any way :)
Duels: Fatandre: I have been wearing my H7 almost every day and I have to say its the best purchase I have made for a long time. They are perfect in any way :) Are you using them on Bluetooth? If so do you get any drop-outs?
The only dropouts I get is when I lets say turn of the computer I need to connect manually again sometimes.
Other than that they work flawlessly. Also the battery holds so long :)
Cleviebaby:Chris, That's rather disconcerting - how much use had they had in that 18 months? Cleve
