Beosound 9000 CD Platter Scraping CDs
machineage
United Kingdom
Posts 69
machineage Posted: Fri, Mar 13 2015 1:43 PM
Hi everyone.
Well I now have a fully functional BS9000 Mk1 following the replacement of the IR PCB. I have subsequently carried out a number of the tests including TM71 & TM73.
However there is a problem with the CD platter - it is scraping the underside of the CDs. I have ensured the suspension setting is correct for the unit to be laid flat on a table. I have also checked / adjusted the two allen screws that adjust the height of the clamper. These have no effect on the height of the CD drive motor / platter. Are there any adjustments that can be made that will alter the height of the CD platter / drive? I couldn't see anything in the service manual.
Thanks!
UPDATE:
OK - I eventually found a post on the forum after more digging that suggested it may be the rocker arm (part 9134) on the underside of the drive mechanism. I removed the arm and it wasn't quite flat across the back - so some gentle persuasion had it flat again and reinstalled. No more disc scraping Smile
valve1
The south of France and occasionally Dublin Ireland
Posts 1,502
valve1 replied on Sat, Mar 14 2015 5:04 AM
machineage:
Well done !  Yes - thumbs up
Fraser9000
Posts 7
Fraser9000 replied on Mon, Nov 23 2015 10:33 PM
Hi. I am the proud new owner of a 9000 and have noticed the scraping on CD in position 3. Also I have noticed that the CDS wobble when playing. Be interested to know if this is normal before I get out my tool box!Fraser
Page 1 of 1 (3 items) | RSS
