Hello fellow Beophiles,
I am having a problem getting a Beogram turntable playing properly in my system.
I have a Beocenter 9500 in one room
and a BeoSystem 6500 (no turntable) in another
I have a Beogram RX and recently acquired a Beogram 5500 and I have MMC2 cartridge/stylus
1.) Am I correct that the Beogram 5500 should work fine as is with either of my systems because it has a factory DIN connection and the Beogram RX2 will require a preamp?
2.) When playing a record on the 5500 with the MC2 in either system I get a muffled, flat, or clipped sound. I am thinking that maybe there is something wrong with the cartridge or stylus.
Any ideas or assistance would be appreciated.
TrojanMBA
Kevin D. Huber
aka Beodude
BeoCemter 9500, BeoSystem 5500, BeoSystem 6500, Penta III, BeoLab 4000, BeoLab 4500, BeoLab 4, BeoMedia 1, BeoSystem 1, BeoSystem 4, BeoLink Passive, BeoLink Active, BeoVox RL40, BeoVox RL60, BeoLab 3500, BeoVision 7-40, Beo4, Beo5, BeoPC, Playmaker,
Lee - I too am having problems with my 5500 turntable linked with the full 5500 system. I am getting a real muffled and distorted sound through my Penta speakers. It has started to happen recently prior to that it was playing wonderfully. I changed the MMC4 to another one and still I am getting the problem. I have moved the styli weight up and down but still no use, in fact the lighter the styli weight the worse the sound. Prior to this I was getting a brilliant sound. Nothing wrong with the pre-amp in the 5500 tuner/amp, even changed the 5500 tuner/amp to a spare one I have and still the same. Would the turntable have a problem?
Thanks David
ProfDAFlynn
Professor David A Flynn JP LM
