BeoMaster 1000
This post has 13 Replies | 1 Follower
SailorJohan
Posts 9
SailorJohan Posted: Wed, Nov 2 2016 3:48 PM
Please tell me if there should be a scale lighting in my BeoMaster 1000. And if, what lamp would it be?
Søren Mexico
Mexico City
Posts 6,411
yes and 2 bulbs 6.3 V 0.3 Amp according to part list, but Dillen on the forum have the right ones, there is one more bulb in there for the stereo light dont remember the voltage
SailorJohan
Posts 9
Thank you Søren! Do you know for Beomaster 900 too?
Søren Mexico
Mexico City
Posts 6,411
SailorJohan:
No but Dillen knows and can supply
SailorJohan
Posts 9
Who/what is Dillen? How do I connect?
SailorJohan
Posts 9
SailorJohan
Posts 9
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Nov 3 2016 7:19 AM
<---  Click on my name and send me en email (if it works).
SailorJohan
Posts 9
I have purchased a used unit and are unsure of the features, it'll be really different strength on the gramophone sound if I use one or the other input?
Søren Mexico
Mexico City
Posts 6,411
SailorJohan:
Your BM has 2 phono inputs, one for TTs with build in preamplifier and the other for TTs without preamp. (the preamp is in the BM)
SailorJohan
Posts 9
Aha, that probably explains the sound difference, thanks Søren!
/Johan
SailorJohan
Posts 9
How do I change the scalebulbs? Do I have to remove the white milked glass under the "scale-needle"?
Dillen
Posts 13,191
Dillen replied on Tue, Nov 8 2016 1:41 PM
Yes, and the common reflector sitting on the lamps.
It should have its opening facing the "mirror".
Good time to clean all the parts, they will need it.
SailorJohan
Posts 9
OK, thank you Martin!
Page 1 of 1 (14 items) | RSS
