Beovision 4-65 3D option
This post has 1 Reply | 0 Followers
11048437
Posts 71
11048437 Posted: Fri, Jan 1 2016 11:47 PM
hi,
I would need your precious help in this matter!!
I wonder if there any chance I can watch a 3D movie on my Beovision 4-65 Mk3?
Beosystem 3 shows in the MENU the 2D and 3D option.   So if i buy a Bluray that simulates 3D,  then adding a pair of passive glasses  , would i get a 3D image on the Beovision?
Thanks in advance ! Any suggestion is welcome!
9 LEE
Eastbourne, UK
Posts 7,218
9 LEE replied on Sat, Jan 2 2016 12:12 PM
No, you will not get 3D on your 4-65 I'm afraid.
Your BeoSystem 3 is clearly running the later software, which allows it to work with BV12-65 panels (BeoSystem 3 was sold with the first generation of BV12-65) hence the '3D' option.
The BeoVision 4 panel was never 3D on any generation.
Lee
Page 1 of 1 (2 items) | RSS
