Beogram 3404 powers on but nothing moves
This post has 2 Replies | 2 Followers
makeITfunctional
Posts 8
makeITfunctional Posted: Fri, Jan 8 2016 8:02 PM
Hello, Forums!
I've got an extremely dusty Beogram 3404 that I dusted off, plugged into the mains and plugged the DIN into the 'Phono' port on the back of my (working) Beomaster 7000. This Beogram 3404 was my Dad's a long time ago, and I know that it worked (at some point).
The Beogram lights up (over the '45' or '33' button - depending which one I select) and it lights up on the 'Start' button, too.
Unfortunately the 'Turn' button doesn't cause the platter to spin nor does pressing 'Start' cause the arm to move.
This seems broken - are there any quick fixes I can try?
Thanks!!
Rich
Orlando, Florida, USA
Posts 2,598
Rich replied on Sat, Jan 9 2016 11:11 PM
Take off the platter and verify the transport screws underneath are loosened.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Jan 10 2016 4:53 PM
- And check that a belt is fitted.
Page 1 of 1 (3 items) | RSS
